I dont have a digital camera so i cant help you out with pictures so ill try to be descriptive. First pop the hook and look at the plastic deal that is over the headlights. You should see a flimsy plastic panel on both sides of the explorer. Once you find that you will see on the smaller side of that panel will be a piece of plastic that is holding it down. just press that twards the center of the truckand the panel should hinge up and fould to the center of the truck. the you will see Two light grey pieces of plastic goint twards the rear of the car with a phillips head screw at the end. remove those two screws and the corner light should just pull out. from my experience the driver side headlight is a tougher to get out but by passenger side one practicall fell out. when you have the light pulled out some you will see three wire looms. just twist each bulbs socket and it will pull loose. switch the bulbs if you choose to now. do what i just said in reverse order with the new lights to reinstall them. i always pull on the wire looms from the back to make sure no wires get pinched when i a installing the lights. On the passenger side i try to pust that corner light to the outside of the car as much as i can since the air intake is behind that. it wont make a real difference but i do it. Hope this heelped let me know if you get stuck anywhere. Major
