Clear side markers fading to a yellowish color.. | Ford Explorer Forums
5ugnst1
CA
'01 Sport
Bought clear corners a while ago, and theyre starting to turn a yellow color. I tried this cleaner but didnt work. Thinking about soaking them in hot water and soap. Someone told a while ago to buy this clear film that protects them, or to use sand paper to bring them back to life.
Anyone have suggestions, or similar DIY posts?
Thanks!
use 1000 wet sand then 2000 wet sand then a headlight polishing kit
I've seen the polishing kits. It's not that though because i tried it, and only the edges are yellow. And it's on the inside. So i'm thinkin that sh*t built up on the inside because I went to change the bulbs and the whole bottom attachment was coming off..i don't know. I'll soak them then let you guys know how it works
