Clearance Question | Ford Explorer Forums
Clearance Question
Offroad19
Ocean Springs,MS
93 Explorer EB
I have a 93 explorer with a 5.5 Suspension lift and a 3inch body do yall think I could run 35x15 TSLs?
Depends on the rims, but with a trimming you shouldn't have much of a problem except at full steering lock.
If I put a 15x10 offset would I have a problem?
15x10 offset? time to get your wheel terms straight ;)
Well **** help a man out..lol what rim do I p ut on there to clear it at full turn?
15x10 is width. offset is the distance of the rim flange from the rim centerline. backspacing is offset - rim 1/2 width.
So to put 35x15 what size rims should i get and everything?
Anyone? Well the rims I am gettin are 15x10 and they have 3.63" backspacing. Can someone help me?
Those rims will work best of any, but you'll still need to trim most likely.
