click noise when I turn | Ford Explorer Forums
Flyguy123456
Vacaville
93' XLT
Hi, I have 93 explorer 4x4 and when ever i make a right turn going 20+ mph it makes this fast clicking noise, but when i make left turns at any speed there is no noise. any sugestions on what might be wrong ?
It sounds like your auto hubs are not completely disengaged.
I switched the auto hubs out with manual ones a few months ago. The problem with the clicking just started about last week.
It could be your pitman arm. We have an F-250 at work that has the same problem and it turned out to be the pitman arm. It should have a grease fitting on it so you should be able to use a grease gun to lube it up. Also check out the ball joints, tie rods, and all other steering linkage.
