Mattbuyshouses
- June 5, 2003
- Rockford, IL
- '95 XLT
First let me say hello all, it's been awhile since I've posted in this forum and I don't know where I'd be today without some of the assistance I've received here on multiple occasions... thanks everyone for being so helpful.
Now on to my new sitch with the sploder....
95 XLT 4x4
Had the brakes completely done last fall (about 6 months ago) rotors turned etc. While I was in there we also corrected a problem I was having with the ABS... replaced the hubs (some info here) http://www.explorerforum.com/forums/showthread.php?t=144250 which corrected the problem with the ABS always kicking in. While the front end was torn open I'm not sure why I didn't just flop the couple extra hundred down and fix the remaining problems I'll never know... I've had this clicking/grinding/crunching sound for sometime now. At low speeds while braking or slow cornering there is a thunk, thunk, thunk sound or loud click while turning left. Had the brakes checked recently to see if something there was causing it. No problems with the brakes, calipers or rotors. All brakes are in great condidtion. We inspected a small hole in the CV boot on the driver's side near the wheel and concluded that could potentially be the problem. Inspected the ball joints etc., and control arms for any play, no issues.
Here's what I'm faced with today. I'm going to throw down the following replacements on Tuesday and wanted to get anyone's feedback as to anything else to do while we're at it.
Half-shaft replacements (59.99 w/30 core) for remans. Both sides.
Lower ball joints (14.99) both sides.
Upper ball joint (69.99) driver side.
Upper ball joint (89.99) passenger side.
Front dif. outer seals (8.99) ea.
Front shocks (light duty) 15.99 ea.
Anything else to do while we're at it? The brakes are already done, the hubs are in great shape, rotors look near perfect... Time to replace the front shocks maybe?
Just wondering if anyone would suggest any other parts to change, fix, inspect, etc., while it's all opened up. We're planning on spending the time it takes to get the thing done so might as well get 'er done!
Thanks for any info!
Matt
95 XLT 4x4
Matt
