Clicking Sound in Center Dash | Ford Explorer Forums
explorerpirate
Woodstock, GA
1997 Ford Explorer (EBed)
When I start my ford explorer I get a click click click click click click sound from what it seems The Center counsoul of The dash, then it stops and a bit of time later it does it again. Any ideas? 1997 Ford Explorer {EB ed.} Thanks, Brian
Maybe it is the blend door actuator?
Try opening the glove box door and listen, the blend door actuator is right behind it if that is what is making the noise.
What can be done?
If that is The reason for The clicking sound, what can be done? Thanks for The input, Brian
The blend door actuator motor has broken teeth/gears. Those are made of plastic, there is nothing you can do but replace that actuator.
Probably the door is stuck on "heating" now (if you have heat), but when you will need A/C it will not work.
