3boydad
- July 1, 2009
- Yardley PA
- 03 xlt
I have a 2003 XLT the truck was stuck in 4X4 H I pulled the fuses did the brown wire mod with no luck. I put the truck up on a set of ramps and pulled the transfer case solenoid motor and found (not surprisingly) that the transfer case was set to 4X4H . I manually reset the motor by putting the vehicle in neutral and put the transfer case into N. I buttoned everyting back up and went to back off the ramps. When I put the truck into reverse a fast clicking began. I put it back into park and tried again to put it into reverse - same fast clicking sound. I then put it in drive,3,2,1 and they engaged without the clicking.
Right now it is still on the ramps as i do not want to move it becuse I am not sure what will happen If i do - Any help or explanation would be greatly appreciated.
