AZRanger346
- September 23, 2009
- Tucson, AZ.
- 98 Explorer Sport 4x4
I have a stock 98 Explorer Sport 4wd. I have a loud banging clunking sound while I am driving. I have done the following and cannot locate what is causing it. I have replaced the transfercase, the planetary gears in the rear diff., the u joints, greased the rear slip yoke, new shocks, new sway bar links and bushings in the front, new exhaust system, new shift motor for the transfer case, the BWM, new tires, new brakes, made sure the spare tire is secure, checked the rear suspension, checked the front u joint and cv joint on the drive shaft. I know it has something to do with the drive line but I cant figure it out. Can someone help before I go insane. I dont know what else to change.
