brysonj
- June 18, 2002
- Powhatan VA 23139
- 95 EB 4x4
Hello all, first time post long time lurker. Hoping someone can help me.
The vehicle is a 1993 Ranger 4x2 3.0 V6. 5 speed manual. 90K original miles.
This truck belongs to a good friend of my family. He brought it to me because the clutch was releasing right at the floorboard. I diagnosed a leaking slave cylinder, and we decided to do the rest of the clutch while the transmission was out.
As with many, bleeding the clutch was difficult when it all came back together. I purchased the "phoenix injector" in an attempt to get the air out of the lines. The clutch seemed to release ok, but I could still only get the truck into 2nd and 4th gear with the engine running. The pedal felt fine, so I opted to go ahead and change the master to compliment the new slave.
Well, I was careful to bleed the slave with the line at the top before bolting to the firewall. The clutch still is having big problems. After a couple of days of fruitless bleeding attempts (think several hours here), I have come to the conclusion that perhaps something else is wrong.
I decided to take the truck out for a drive. As long as the truck is in first gear when I start the engine, the truck is very driveable and shifts almost flawlessly. The clutch pedal is firm. The release / friction point is at the oem position -- about midway through clutch travel. However, if the truck comes to a stop and you're not in gear, you have to shut the motor off to get back into gear -- again, then everything is fine and in fact you can shift through all the gears driving as fast as you want.
This is a frustrating problem. Where should I go next?
1. Should I take it to an "expert" to bleed this thing? Based on the friction point of the clutch, I am skeptical that further bleeding will solve this problem.
2. There is a rubber portion of the hydraulic line (about 6") between the master and the slave. Is it possible that this line is damaged internally (after 13 years) and needs replacement?
3. Despite the proper feeling of the clutch, is it possible the new clutch disc / pressure plate is in some way defective?
4. Some kind of problem with the transmission (seems unlikely, but again I am lost here)
