Clutch Slipping on 92 X | Ford Explorer Forums
ckiel
Columbus, IN
1992 Sport 2-door
How much are clutches & Installation (est.) on this 4x4? Thanks,
-ckiel-
If you do it yourself you can probably do it for under 350, that includes clutch plate, pressure place, new throwout bearing, slave cylinder. Done...maybe around 900 (mine did). This is a job you can do yourself, we didn't cause we didn't have a place to do it and it was the dead of winter.
code
very vague question, i would call around local places to you... here in northern california labor rate is around $85/hour for a standard repair shop... i dont even want to try to htink about what the dealer charges... also it depends on what clutch you get as well, a stock or replacement clutch will be hundreds cheaper than say a centerforce dual friction performance clutch... remove to also have replacesd the slave cylinder, throwout bearing, pilot bearing, and have the flywheel resurfaced
ive used LUK clutches in my '92 whenever it went. i think they are like $350
