Code 335 and 542 for no start? | Ford Explorer Forums
bobbyrayjr85
1995 Ford Explorer 4x4
335 O EGR Sensor voltage out-of-range
542 O,C Fuel Pump circuit open; PCM to motor
Can someone explain this in better detail
and the 542 is that bad ground or the whole pump ?
And pretty sure 542 will be crank no start but will both cause it?
ignore 335 for right now, it wont cause any no start concerns. 542 could be the pump, or a wiring problem. check for power and ground at the pump, and if you have both then it is the pump. IIRC there will be 2 wires hot, one hot in run, and one hot in run while running and for 3-5 sec when you turn on the key
How would I check for Power and Ground at pump. Is there a video of this maybe?
Also when I turn key to On I hear a Click at The fuse relay ? but no pump
