bsgraham98
- March 24, 2021
- Omaha, NE
- 2015 PIU
Hello,
I recently purchased a 2015 PIU. After about a week of driving, the check engine light came on (not terribly surprised, that's what you get with used vehicles). I pulled the codes and got the following info:
P0138 (O2 sensor)
P144a (purge valve)
I was wondering if it was common for both of these codes to "blow" at the same time. I'm also experiencing some RPM flutter beginning around 1200 and a noticeable loss of power. Would either/both of these problems cause the RPM problem? I just bought a purge valve to replace the old one, but haven't installed it yet. I figured I'd start with the cheap and easy stuff first. I'm also going to take a look at the wiring harness when the weather is a bit better. I believe the 2 connectors for each part are near each other, so it could just be an electrical problem.
P0138 (O2 sensor)
P144a (purge valve)
