90ranajo
The Little TJ that could
- April 21, 2002
- Pattaya, Chonburi
- 2012 Toyota Fortuner
- Callsign
- KG7MXH
For all of you with 1995 & up Fords, be it Explorer/Rangers or Mustangs or PSDs, I just acquired one of the best laptop scan tools on the market. Auto Enginuity can do the following:
Although Ford does implement the largest subset of the OBDII standard compared to any other manufacturer, the typical vehicle only supports 20 - 40 sensors and is limited to emissions powertrain. Using the enhanced Ford interface, a typical Ford vehicle will support 200 - 300 sensors within half a dozen systems; that's essential systems like ABS, airbags, GEM, etc.
Our enhanced Ford interface coverage is only matched by factory tools; we have support for 3400+ sensors selected from all 55 systems. The Ford enhanced interface has support for Ford of Europe models such as Ka, Mondo, Galaxy, Fairlane, etc. Finally, our Ford enhanced has support for 321 bi-directional commands and dozens of system-level tests. With bi-directional controls, you will no longer be relegated to being just an observer in the operation of the vehicle--now you can take control of its operation.
System Tests:
* PATS Key Programming ('96 - '07)
* KOEO
* KOER
* EVAP Bay Test
* Service Bleed
* Buzz Injector
* Cylinder Contribution Test
* Switch
* Glow Plug Test
* System Self-Test
* Hi Speed Fan
* Lo Speed Fan
* KAM Reset
* Tire Size Programming up to 40" ('99-'03 7.3L, '04-'07 6.0L and gas trucks Coming Soon)
* IVD Initialization
* Steering Angle / Yaw Rate /Acceleration Sensor Reset ('03 Explorer and Lincoln LS)
* Passenger Seat ReZero
* Power Seat Calibration Test
* Audio Network Communication Test
* Vehicle In-Motion IO Test
* Front Wiper Self-Test
* Rear Wiper Self-Test
* All Outputs On/Off
System Tests:
* KOEO
* KOER
* EVAP Bay Test
* Service Bleed
* Buzz Injector
* Switch
* Glow Plug Test
* System Self-Test
* Hi Speed Fan
* Lo Speed Fan
* KAM Reset
