natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
Yep, in the same way a bad coil can burn through an old school distributor cap.
$20 plug wires can have the same effect. $75 dollar plug wires can actually carry 80 Kv without leaking.
Cheap parts = cheap results.
Not say'n you buy cheap parts, just adding that frequently, people cheap out and then struggle to find the problem.
I figured we should start a new thread for this.
I bought the 'premium' line at Napa, the Belden wires which are $36 currently. Being that I've made audio cables before, Belden is a trusted brand in that area. I purchased the set new on April 7th 2014 and had to replace them on March 31st of this year due to 1 wire having gone bad internally (no external burning, rubbing or breaking). Now, 2 months later, I hear a light misfire at idle when warm. Nowhere near as bad as it was before I exchanged the wires but it's an issue that gets progressively worse.
Anyway, how can a coil go bad to fry wires? I've tested mine when cold and hot and the resistance of the primary & secondary coils is right in spec. I don't see how a coil could suddenly increase in voltage and fry wires or is there something else I'm missing.
Forgive my newbie understanding, the Explorer is the first car I've done serious work on and I haven't messed much with distributor setups.
