I don't have any pix of blocking the air off outside...But its not difficult.
Pop the passenger wiper arm off.
Pop the cowl grill off (its just snapped on but requires a good pull)
Under that you'll see a triangular shaped cover thats sealed in place, you can pry it off carefully so you don't damage it.
Here's where you get your wife as she hopefully has smaller arms than you
I used a quality clear packing tape to seal up the opening that pulls in outside air. The opening is inside up under the bottom of the windshield.
You should be able to cover 80-90% of it, or more depending how far you can get a hand in there.
I used a few dabs of black silicone to stick the triangular shaped cover back in place. Snap the cowl grill back in, and install the wiper arm. Done!
