nctrader77
- December 18, 2003
- Charlotte NC
- 2000 Ford Explorer XLT
I can't believe I put up with the cold start problem, and the chain rattle problem for three winters. I finally went to the Ford parts counter and bought the kit for TSB 00M12. It only cost $40 bucks and took about 3 hours to install. If you are haveing the same cold start problem with your SOHC, and are no longer covered by the recall, this kit should be installed. It was not too bad, and did not require any special tools. Before you start make sure you have a #30 torqx socket head, and a good size deep well socket, (I think it was a 1-1/16"). The guy at my Ford counter printed the procedure for me. The old intake gaskets were rock hard. The new ones were like rubber. Make sure you clean the maniford mating surfaces very good, and don't get any crap down the intake. Everything went together with no real problem, if you take your time. I was so happy to have the thing start properly in cold weather, I could have kicked myself for not doing it sooner.
