devil driver
- September 2, 2009
- fieldon il
- 96 xlt
I have a 96 ex with the 5.0 engine. On cool mornings when I start it, it will run for several seconds and then sputter and die. I then can turn the key to off, then restart and it will run fine. On warm mornings I can start and it will run fine. This morning it is colder out and it took 5 tries before it would start and run. So the colder it is the worse it gets. I have replaced the intake air temp sensor, and the tps but those did not help. The only code that comes up is 0446, which I dont believe would cause the problem. If I start it and try to drive, it will give me problems until I shut it off and restart, then it runs great. Also it is worse under load, like going up hill. Let me know what you all might think the problem is. Thanks
