Column Shift AOD question | Ford Explorer Forums
Hammer
Scottsdale, AZ
91 4Door 4X4 Explorer XLT
Anyone know if I can retain the stock automatic Column shift in my 91 Ex when I install the AOD?
Not really wanting to get a floor shift right now.
Let me know ASAP the HO 5.0 with Atlas 5.0 and AOD is happening this weekend :confused:
I posted the shift sequence on the AOD shifter in your other post of this question. I tend to answer double posts once.
I guess my question was a bit vauge.
Are the throws the same?
If I get the cable hooked up will the throws from the stock column shifter be the same?
If the sequence is the same it can be made to work. Whether stock throw is correct without help or not I cannot say.
