If you use OEM throttle brackets, or carburetor, and the cables, then it is a simple adjustment to make with the proper manual. So if you used 92 Mustang parts, then it would be easy to look at a shop manual for that car.
It usually amounts to setting the cable at a starting reference point, and then inserting a spacer tool to be able to set the adjustment. The spacer is just that, and shop manuals usually tell you what the thickness is, so you grab a drill bit that size etc.
I made the point about the adjustment because it should be done before starting the engine, and especially before driving it. The needed idle pressure is about 5psi, but that must increase immediately with more throttle. The adjustment (spacer) pressure is something like 33psi. If there is no pressure just over idle(driving), the TV pressure in the valve body will be too low, and clutch slippage will kill the trans very fast.
If you do go that route with an AOD, make sure to check the TV cable bushings. They are plastic and unless the mileage is low, they are worn out or will be soon. When they get loose, the cable falls off and the TV pressure drops to zero. I love the old AOD's but there are some things that will be forgotten over the years. Regards,
