00whxploder
- February 9, 2010
- Fitzgerald, GA.
- 2000 xls 4x4 now
Okay so I need help from the SAS guys on here.
I have found a wagoner with the complete front end at my buddies junk yard.He is letting me get the LPD44 and leafs from it for $150.
I will be putting it on leafs so the stock wagon spring will hold me up...
I will be running Reid Racing Heavy Duty Flat Top Knuckle.
https://www.4wdfactory.com/store/products.php?product=Reid-Racing-%28Dedenbear%29%3A-D44-GM-%7B47%7D-Chevy-and-Jeep%2C-Heavy-Duty-Flat-Top-Knuckle
I will be cheating by using Sky Manufacturing Chevy S-10 Solid Axle Hanger Kit which can be modded if need be.https://www.4wdfactory.com/store/products.php?product=Chevy-S%252d10-Solid-Axle-Hanger-Kit
I have read a lot of the threads but when it all comes down I need the easiest steering box set-up. Which way should I go?
Will I have to modify the drive shaft and should I get the drive shaft out of the wagon at the same time.
As for the rear will the axle out of a 93 f150 be the same length.
Any Advice will be greatly appreciated.
