Computers, Sensors, MILs, CELs, PCM Inputs and More | Page 2 | Ford Explorer Forums
sparky2263 said:
Once the MIL is illuminated, three consecutive drive cycles without a malfunction detected are required to extinguish the MIL. The DTC is erased after 40 engine warm-up cycles once the MIL is extinguished.
Freeze frame data is stored at the time the first malfunction is detected, however, previously stored conditions will be replaced if a fuel or misfire fault is detected.
Description of OBDII Drive Cycle
The following procedure is designed to execute and complete the OBDII monitors and to clear the Ford P1000, I/M readiness code. To complete a specific monitor for repair verification, follow steps 1 through 4, then continue with the step described by the appropriate monitor found under the "OBDII Monitor Exercised" column. When the ambient air temperature is outside 4.4 to 37.8°C (40 to 100° F), or the altitude is above 2438 meters (8000 feet), the EVAP monitor will not run. If the P1000 code must be cleared in these conditions, the PCM must detect them once (twice on some applications) before the EVAP monitor can be "bypassed" and the P1000 cleared. The Evap "bypassing" procedure is described in the following drive cycle.
The OBDII Drive Cycle will be performed using a scan tool. Consult the instruction manual for each described function. NOTE: A detailed description of a Powertrain Control Module (PCM) Reset is found in this section, refer to the table of contents.
Drive Cycle Recommendations:
Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised Drive Cycle Procedure
Purpose of Drive Cycle Procedure
Drive Cycle Preparation
1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status.
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE. Start vehicle WITHOUT returning to Key Off.
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).
Prep for Monitor Entry
4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000.
Engine warm-up and provide IAT input to the PCM.
HEGO
5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor.
EVAP
6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))
Catalyst
7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor.
EGR
8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor.
SEC AIR/CCM (Engine)
9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM.
CCM (Trans)
10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM.
Misfire & Fuel Monitors
11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor.
Readiness Check
12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed.
Pending Code Check and Evap Monitor "Bypass" Check
13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14. Determines if a pending code is preventing the clearing of P1000.
14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
some time back there was a rather humorous thread on someone with an illuminated CEL..... frustrated us all. At the end Robert posted the following explaination of a "drive cycle" from his owner's manual. I (for the more **** amongst us) posted the above description that Sparky posted. Robert's owner's manual description may be more understandable for the layman.... (and not exactly entirely accurate)..
Here is Robert's owner's manual language:
"If the vehicle’s powertrain system
or its battery has just been
serviced, the OBD-II system is
reset to a “not ready for I/M test”
condition. To ready the OBD-II
system for I/M testing, a minimum
of 30 minutes of city and highway
driving is necessary as described
below:
[What follows is more or less a D/C]
² First, at least ten minutes of
driving on an expressway or
highway.
² Next, at least twenty minutes
driving in stop and go, city type
traffic with at least four idle
periods.
Allow the vehicle to sit for at least
8 hours without starting the
engine. Then, start the engine and
complete the above driving cycle.
The engine must warm up to it’s
normal operating temperature.
Once started, do not turn off the
engine until the above driving
cycle is complete."
So, In essence, starting your car in the morning, driving a 10 minute commute on easy freeway traffic, then getting onto surface streets to get to the office, in stop and go downtown traffic, parking at work, and coming back after work and starting home would approximate one drive cycle.
On my 93 with an air bag, I get a code 12 flashing the air bag light all of the time. According to Ford, it means that there was some fluctuation, or power loss in the air bag circuit. If I would disconnect the battery, wait 10 minutes, then reconnect it again, would that solve my problem? Why would it store that code in the first place if the alternator is good, and the battery cables weren't disconncected, and then reconnected again abruptly?
disconnecting the battery may eliminate THIS DTC, but it likely will reappear. meanwhile you erase all the stored things in the memory (STFT, LTFT, Idle air etc...). Better to use a scan tool to erase it, and see if it returns if that is your strategy. If it was a one time thing, it will go away on its own after a number of drive cycles. If it persists, there is a reason.
Moral. Simply unhooking the battery is not a fix, and has some negative consequences.
Some folks even think that once they unhook the battery and then reconnect it if the CEL light (MIL indicator etc) goes off, they somehow magically "fixed" the problem - NOT. That is what this forum is for, to explain why and how that lights goes on.
pcm Imputs
Air Conditioning Cycling Switch
The Air Conditioning (A/C) cycling switch may be wired to either the ACCS or ACPSW PCM input. When the A/C cycling switch opens, the PCM will turn off the A/C clutch. The A/C Cycling Switch (ACCS) circuit to the PCM provides a voltage signal which indicates when the A/C is requested. When the A/C demand switch is turned on, and both the A/C cycling switch and the high pressure contacts of the A/C high pressure switch (if equipped and in circuit) are closed, voltage is supplied to the ACCS circuit at the PCM. Refer to the applicable Wiring Diagram for vehicle specific wiring.
If the ACCS signal is not received by the PCM, the PCM circuit will not allow the A/C to operate. For additional information, refer to PCM outputs, wide open throttle air conditioning cutoff.
NOTE: The Town Car and Continental do not have a dedicated (separate) input to the PCM indicating that A/C is requested. This information is received by the PCM through the BUS + and BUS - (SCP) communication.
A/C Pressure Sensor Output Voltage VS Pressure Chart
attachment.php
Typical Air Conditioning Pressure Sensor
attachment.php
The air conditioning pressure (A/C pressure) sensor is located in the high pressure (discharge) side of the air conditioning A/C system. The A/C pressure sensor provides a voltage signal to the Powertrain Control Module (PCM) that is proportional to the A/C pressure. The PCM uses this information for A/C clutch control, fan control and idle speed control.
Air Conditioning High Pressure Switch
The A/C high pressure switch is used for additional A/C system pressure control. The A/C high pressure switch is either dual function for two-speed electric fan applications or single function for all others.
For refrigerant containment control, the normally closed high pressure contacts open at a predetermined A/C pressure. This will result in the A/C turning off, preventing the A/C pressure from rising to a level that would open the A/C high pressure relief valve.
For fan control, the normally open medium pressure contacts close at a predetermined A/C pressure. This grounds the ACPSW circuit input to the PCM. The PCM will then turn on the high speed fan to help reduce the pressure.
Typical Brake Pedal Position Switch
attachment.php
The Brake Pedal Position (BPP) switch is used by the PCM to disengage the transmission torque converter clutch and on some applications as an input to the idle speed control for idle quality. On most applications the BPP switch is hard wired to the PCM and supplies battery positive voltage (B+) when the vehicle brake pedal is applied. On other applications the BPP switch signal is broadcast over the SCP link via another module to be received by the PCM.
On applications where the BPP switch is hard wired to the PCM and stoplamp circuit, if all stoplamp bulbs are burned out (open), high voltage is present at the PCM due to a pull-up resistor in the PCM. This provides fail-safe operation in the event the circuit to the stoplamp bulbs has failed.
Typical Hall-Effect Sensor
Typical Variable Reluctant Sensor
Camshaft Position Sensor
The Camshaft Position (CMP) sensor detects the position of the camshaft. The CMP sensor identifies when piston No.1 is on its compression stroke. A signal is then sent to the powertrain control module and used for synchronizing the firing of sequential fuel injectors. The Coil On Plug (COP) Ignition applications also use the CMP signal to select the proper ignition coil to fire. The input circuit to the PCM is referred to as the CMP input or circuit.
There are two types of CMP sensors: the three pin connector Hall-effect type sensor and the two pin connector variable reluctance sensor.
Typical Clutch Pedal Position (CPP)/Park-Neutral Position (PNP) Switches
Clutch Pedal Position Switch
The Clutch Pedal Position (CPP) switch is an input to the PCM indicating the clutch pedal position and, in some manual transmission applications, both the clutch pedal engagement position and the gear shift position. The PCM provides a 5-volt reference (VREF) signal to the CPP switch and/or a Park/Neutral Position (PNP) switch (on the CPP signal line). If the CPP switch (either or both CPP and PNP switches are closed) is closed, indicating the clutch pedal is engaged and the shift lever is in the NEUTRAL position, the output voltage (5 volts) from the PCM is grounded through the signal return line to the PCM, and there is 1 volt or less. One volt or less indicates there is a reduced load on the engine. If the CPP switch (or PNP switch on vehicle or both CPP and PNP switches open on the vehicle) is open, meaning the clutch pedal is disengaged (all systems) and the shift lever is not in NEUTRAL position (PNP switch systems), the input on the CPP signal to the PCM will be approximately 5 volts . Then, the 5-volt signal input at the PCM will indicate a load on the engine. The PCM uses the load information in mass air flow and fuel calculations.
Three Different Types Of Crankshaft Position (CKP) Sensors
Crankshaft Position Sensor (Integrated Ignition Systems)
The Crankshaft Position (CKP) sensor is a magnetic transducer mounted on the engine block adjacent to a pulse wheel located on the crankshaft. By monitoring the crankshaft mounted pulse wheel, the CKP is the primary sensor for ignition information to the powertrain control module. The trigger wheel has a total of 35 teeth spaced 10 degrees apart with one empty space for a missing tooth. The 6.8L ten cylinder pulse wheel has 39 teeth spaced 9 degrees apart and one 9 degree empty space for a missing tooth. By monitoring the trigger wheel, the CKP indicates crankshaft position and speed information to the PCM. By monitoring the missing tooth, the CKP is also able to identify piston travel in order to synchronize the ignition system and provide a way of tracking the angular position of the crankshaft relative to fixed reference.
Cylinder Head Temperature (CHT) Sensor
Cylinder Head Temperature Sensor
The Cylinder Head Temperature (CHT) sensor is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as temperature increases, and increases as temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to temperature.
Thermistor-type sensors are considered passive sensors. A passive sensor is connected to a voltage divider network so that varying the resistance of the passive sensor causes a variation in total current flow.
Voltage that is dropped across a fixed resistor in series with the sensor resistor determines the voltage signal at the PCM. This voltage signal is equal to the reference voltage minus the voltage drop across the fixed resistor.
The cylinder head temperature sensor is installed in the aluminum cylinder head and measures the metal temperature. The CHT sensor communicates an overheating condition to the PCM. The PCM would then initiate a cooling strategy based on information from the CHT sensor. A cooling system failure such as low coolant or coolant loss could cause an overheating condition. As a result, damage to major engine components could occur. Using a CHT sensor and cooling strategy would prevent damage by allowing air cooling of the engine and limp home capability.
Differential Pressure Feedback EGR Sensor
For information on the differential pressure feedback EGR sensor, refer to the description of the Exhaust Gas Recirculation Systems.
Engine Coolant Temperature (ECT) Sensor
The Engine Coolant Temperature (ECT) sensor is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases, and increases as the temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to temperature.
Voltage that is dropped across a fixed resistor in a series with the sensor resistor determines the voltage signal at the PCM. This voltage signal is equal to the reference voltage minus the voltage drop across the fixed resistor.
The ECT measures the temperature of the engine coolant. The sensor is threaded into an engine coolant passage. The ECT sensor is similar in construction to the IAT sensor.
Engine Fuel Temperature (EFT) Sensor
Engine Fuel Temperature Sensor
The Engine Fuel Temperature (EFT) sensor is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as temperature increases, and increases as temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to temperature.
The EFT sensor measures the temperature of the fuel near the fuel injectors. This signal is used by the PCM to adjust the fuel injector pulse width and meter fuel to each engine combustion cylinder.
Engine Oil Temperature
The Engine Oil Temperature (EOT) sensor is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases and increases as the temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to temperature.
The EOT measures the temperature of the engine oil. The EOT sensor is similar in construction to the Engine Coolant Temperature (ECT) sensor. On some applications, EOT input to the PCM is used to initiate a soft engine shutdown. This prevents engine damage from occurring as a result of high oil temperature.
Flexible Fuel (FF) Sensor
Flexible Fuel Sensor
The Flexible Fuel (FF) sensor is a capacitive device with a signal processing stage whose frequency varies with the dielectric constant, conductivity and temperature of the methanol-gasoline fuel mixture in its measuring cell. In general, as the percentage of methanol in the fuel mixture increases, the output frequency of the FF sensor signal will increase. For example, a fuel mixture that is 30% methanol will have a FF sensor signal output frequency between 60 and 100 Hz ; 60% methanol will have a FF sensor signal output frequency between 90 and 130 Hz . The PCM uses the percent methanol information to calculate the correct air/fuel ratio and spark advance for the vehicle.
Fuel Level Input
The Fuel Level Input (FLI) is a hard wire signal input to the PCM from the Fuel Pump (FP) module. Refer to the description of the FLI in the On-Board Diagnostics II Monitors.
Fuel Pump Monitor - Applications Using a Fuel Pump Relay for Fuel Pump ON/OFF Control
The Fuel Pump Monitor (FPM) circuit is spliced into the fuel pump power (FP PWR) circuit and is used by the PCM for diagnostic purposes. The PCM sources a low current voltage down the FPM circuit. With the fuel pump off, this voltage is pulled low by the path to ground through the fuel pump. With the fuel pump off and the FPM circuit low, the PCM can verify that the FPM circuit and the FP PWR circuit are complete from the FPM splice through the fuel pump to ground. This also confirms that the FP PWR or FPM circuits are not shorted to power. With the fuel pump on, voltage is now being supplied from the fuel pump relay to the FP PWR and FPM circuits. With the fuel pump on and the FPM circuit high, the PCM can verify that the FP PWR circuit from the fuel pump relay to the FPM splice is complete. It can also verify that the fuel pump relay contacts are closed and there is a B+ supply to the fuel pump relay.
Fuel Pump Driver Module Applications
The Fuel Pump Driver Module (FPDM) communicates diagnostic information to the powertrain control module through the Fuel Pump Monitor circuit. This information is sent by the FPDM as a duty cycle signal. The three duty cycle signals that may be sent are listed in the table.
Fuel Tank Pressure Sensor
For information on the Fuel Tank Pressure (FTP) sensor, refer to the description of the Evaporative Emission Systems.
Fuel Rail Pressure (FRP) Sensor
Fuel Rail Pressure Sensor
The Fuel Rail Pressure (FRP) sensor is a diaphragm strain gauge device in which resistance changes with pressure. The electrical resistance of a strain gauge increases as pressure increases, and decreases as pressure decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to pressure.
Strain gauge type sensors are considered passive sensors. A passive sensor is connected to a voltage divider network so that varying the resistance of the passive sensor causes a variation in total current flow.
The FRP sensor measures the pressure of the fuel near the fuel injectors. This signal is used by the PCM to adjust the fuel injector pulse width and meter fuel to each engine combustion cylinder.
The fuel rail pressure sensor senses the pressure difference between the fuel rail and the intake manifold. The return fuel line to the fuel tank has been deleted in this type of fuel system. The differential fuel/intake manifold pressure together with measured fuel temperature provides an indication of the fuel vapors in the fuel rail. Both differential pressure and temperature feedback signals are used to control the speed of the fuel pump. The speed of the fuel pump sustains fuel rail pressure which preserve fuel in its liquid state. The dynamic range of the fuel injectors increase because of the higher rail pressure, which allows the injector pulse width to decrease.
Generator Monitor (Gen Mon)
For information on the generator monitor, refer to the description of the PCM/Controlled Charging System.
Generator Load
The Generator Load Input (GLI) circuit is used by the PCM to determine generator load on the engine. As generator load increases the PCM will adjust idle speed accordingly. This strategy helps reduce idle surges due to switching high current loads. The GLI signal is sent to the PCM from the voltage regulator/generator. The signal is a variable frequency duty cycle. Normal operating frequency is 40-250 Hz . Normal signal DC voltage (referenced to ground) is between 1.5 V (low generator load) and 10.5 V (high generator load).
Heated Oxygen Sensor
The Heated Oxygen Sensor (HO2S) detects the presence of oxygen in the exhaust and produces a variable voltage according to the amount of oxygen detected. A high concentration of oxygen (lean air/fuel ratio) in the exhaust produces a low voltage signal less than 0.4 volt . A low concentration of oxygen (rich air/fuel ratio) produces a high voltage signal greater than 0.6 volt . The HO2S provides feedback to the PCM indicating air/fuel ratio in order to achieve a near stoichiometric air/fuel ratio of 14.7:1 during closed loop engine operation. The HO2S generates a voltage between 0.0 and 1.1 volts .
Embedded with the sensing element is the HO2S heater. The heating element heats the sensor to temperatures of 800°C (1400°F) . At approximately 300°C (600°F) the engine can enter closed loop operation. The VPWR circuit supplies voltage to the heater and the PCM will complete the ground when the proper conditions occur. For model year 1998 a new HO2S heater and heater control system are installed on some vehicles. The high power heater reaches closed loop fuel control temperatures. The use of this heater requires that the HO2S heater control be duty cycled, to prevent damage to the heater. The 6 ohm design is not interchangeable with new style 3.3 ohm heater.
Typical Intake Air Temperature (IAT) Sensors
Intake Air Temperature Sensor
The Intake Air Temperature (IAT) sensors are thermistor devices in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases, and increases as the temperature decreases. The varying resistance affects the voltage drop across the sensor terminals and provides electrical signals to the PCM corresponding to temperature.
The IAT provides air temperature information to the PCM. The PCM uses the air temperature information as a correction factor in the calculation of fuel, spark and MAF.
The IAT sensor provides a quicker temperature change response time than the ECT sensor.
Intake Manifold Runner Control
For information on the Intake Manifold Runner Control (IMRC) , refer to the description of the Intake Air Systems.
Knock Sensor (KS)
Knock Sensor
The Knock Sensor (KS) is a tuned accelerometer on the engine which converts engine vibration to an electrical signal. The PCM uses this signal to determine the presence of engine knock and to retard spark timing.
Typical Mass Air Flow (MAF) Sensor
Diagram Of Air Flow Through Throttle Body Containing MAF Sensor Hot And Cold Wire (and IAT Sensor Where Applicable) Terminals
Diagram of Air Flow through Throttle Body contacting MAF sensor hot and cold wire (and IAT sensor hot wire where applicable) terminals.
Mass Air Flow Sensor
The Mass Air Flow (MAF) sensor uses a hot wire sensing element to measure the amount of air entering the engine. Air passing over the hot wire causes it to cool. This hot wire is maintained at 200°C (392°F) above ambient temperature as measured by a constant cold wire. If the hot wire electronic sensing element must be replaced, then the entire assembly must be replaced. Replacing only the element may change the air flow calibration.
The current required to maintain the temperature of the hot wire is proportional to the air mass flow. The MAF sensor then outputs an analog voltage signal to the PCM proportional to the intake air mass. The PCM calculates the required fuel injector pulse width in order to provide the desired air/fuel ratio. This input is also used in determining transmission Electronic Pressure Control (EPC) , shift, and torque converter clutch scheduling.
Some MAF sensors have Integrated Bypass Technology (IBT) with an integrated Intake Air Temperature (IAT) sensor. The present applications with IBT are: Escort/Tracer (4V) , 2.0L Contour/Mystique, Windstar, Explorer/Mountaineer and 4.2L E-Series.
The MAF sensor is located between the air cleaner and the throttle body or inside the air cleaner assembly.
Power Steering Pressure (PSP) Switch
Power Steering Pressure Switch
The Power Steering Pressure (PSP) switch monitors the hydraulic pressure within the power steering system. The PSP switch is a normally closed switch that opens as the hydraulic pressure increases. The PCM uses the input signal from the PSP switch to compensate for additional loads on the engine by adjusting the idle rpm and preventing engine stall during parking maneuvers. Also, the PSP switch signals the PCM to adjust transmission electronic pressure control pressure during the increased engine load, for example during parking maneuvers.
Power Steering Pressure (PSP) Sensor
Power Steering Pressure Sensor
The power steering pressure sensor monitors the hydraulic pressure within the power steering system. The PSP sensor is a normally closed and opens as the hydraulic pressure increases. The PCM uses the input signal from the PSP sensor to compensate for additional loads on the engine by adjusting the idle rpm and preventing engine stall during parking maneuvers. Also, the PSP sensor signals the PCM to adjust transmission Electronic Pressure Control (ECP ) pressure during the increased engine load, for example during parking maneuvers.
Power Take-Off (PTO) Switch And Circuit To PCM
Power Take-Off Switch and Circuit
The Power Take-Off (PTO) circuit is used by the PCM to disable some of the OBD II Monitors during PTO operation. The PTO circuit normally carries low voltage. When the PTO switch is on/closed, B+ is supplied to the PTO input circuit indicating to the PCM that an additional load is being applied to the engine. If this action was not reported by the PTO circuit, a false Diagnostic Trouble Code may be stored.
Purge Flow Sensor
For information on the Purge Flow (PF) sensor, refer to the description of the Evaporative Emission Systems.
Throttle Position Sensor
The throttle position sensor is a rotary potentiometer or Hall-effect sensor that provides a signal to the PCM that is linearly proportional to the throttle plate/shaft position. The sensor housing has a three-blade electrical connector that may be gold plated. The gold plating increases corrosion resistance on terminals and increases connector durability. The TP sensor is mounted on the throttle body. As the TP sensor is rotated by the throttle shaft, four operating conditions are determined by the PCM from the TP. Those conditions are closed throttle (includes idle or deceleration), part throttle (includes cruise or moderate acceleration), wide open throttle (includes maximum acceleration or de-choke on crank), and throttle angle rate.
Transmission Control Switch (TCS)
The Transmission Control Switch (TCS) signals the PCM with keypower whenever the TCS is pressed. On vehicles with this feature, the Transmission Control Indicator Lamp (TCIL) lights when the TCS is cycled to disengage overdrive. The operator of the vehicle controls the position of the TCS.
Solid State Relay
For information on the solid state relay, refer to the description of the Secondary Air Injection Systems.
Vehicle Speed Sensor (VSS)
The Vehicle Speed Sensor (VSS) is a variable reluctance or Hall-effect sensor that generates a waveform with a frequency that is proportional to the speed of the vehicle. If the vehicle is moving at a relatively low velocity, the sensor produces a signal with a low frequency. As the vehicle velocity increases, the sensor generates a signal with a higher frequency. The PCM uses the frequency signal generated by the VSS (and other inputs) to control such parameters as fuel injection, ignition control, transmission/ transaxle shift scheduling and torque converter clutch scheduling.
4X4 Low Touch Drive Button (Switch)
The Generic Electronic Module (GEM) provides the PCM with an indication of 4x4L. This input is used to adjust the shift schedule. A 5.0 volt module pull-up indicates 4x4H or 4x2.
29 pics to stick in that thread and I've loaded my maximum of 3...........
People sometimes fail to realize the work in putting in photo posts, or for that matter doing a photo thread.
I put my photos in the Explorer Forum photo gallery. Hence I can open two instances of Explorer forum (running it twice simaltaneously) and bounce back and forth between them pasting the pic address from the gallery into the thread post in progress, it saves a LOT of time.
Sparky - I really think you should put all these in their own thread, they deserve better exposure.
:banghead:
.....doing that now.........
I'll do outputs another time and you can move this/edit/whatever you think will do the most good.
I haven't seen any posts from Robert for quite some time. He is always willing to test things out and explain how he did it. Has anyone heard from him?
I haven't seen him here in quite a long time. I agree, he was damned good.
And Sparky, this ain't my forum, so I'll leave it to ExplorerDMB and his co-Mod to figure out what they want to do.
What I have done is Merged the "computer sub-forums" thread into the Introduction to Computers thread. I have added more to the title, which I can change if something else should be there, but I decided to do it this way so that people have a easier time finding it instead of looking under the thread "computer sub-forums" which was talking about how people don't use the section and about SLR Cameras (somehow that slid in there?). Anyway, if there is a problem with the way I have done it, PM me -- if not, keep the information coming! :thumbsup:
Sparky226 and Glacier991 - You two are doing a great thing for this site. Thank you.
-Drew
Powertrain Control Software
The increased number of modules on the vehicle dictates a more efficient method of communication. Multiplexing is the process of communicating several messages over the same signal path. This process allows multiple modules to communicate with each other through the signal path (BUS+/BUS-). Modules communicate with the powertrain control module using Standard Corporate Protocol (SCP) which determines the priority in which the signals are sent. (Refer to Standard Corporate Protocol for more information.) Multiplexing reduces the weight of the vehicle by reducing electrical wiring.
The Standard Corporate Protocol is a communication language used by Ford Motor Company for exchanging bi-directional messages (signals) between stand-alone modules and devices. Two or more signals can be sent over one circuit.
Included in these messages is diagnostic data that is output over the BUS+ and BUS - lines to the Data Link Connector (DLC) . This information is accessible with a scan tool. Information on this equipment is described in Diagnostic Methods.
Flash Electrically Erasable Programmable Read Only Memory
The Flash Electrically Erasable Programmable Read Only Memory (EEPROM) is an Integrated Circuit (IC) within the PCM. This IC contains the software code required by the PCM to control the powertrain. One feature of the EEPROM is that it can be electrically erased and then reprogrammed without removing the PCM from the vehicle. If a software change is required to the PCM, the module no longer needs to be replaced, but can be reprogrammed at the dealership through the Service Bay Diagnostic System(R) (SBDS(R)) . The reprogramming is done through the DLC.
Idle Air Trim
Idle Air Trim is designed to adjust the Idle Air Control (IAC) calibration to correct for wear and aging of components. When engine conditions meet the learning requirement, the strategy monitors the engine and determines the values required for ideal idle calibration. The Idle Air Trim values are stored in a table for reference. This table is used by the PCM as a correction factor when controlling idle speed. The table is stored in keep Alive Random Access Memory (RAM) and retains the learned values even after the engine is shut off. A Diagnostic Trouble Code (DTC) is output to indicate that the Idle Air Trim has reached its learning limits.
Whenever an IAC component is replaced or cleaned or a service affecting idle is performed, it is recommended that Keep Alive RAM be cleared. This is necessary so the idle strategy does not use the previously learned idle air trim values. It is important to note that erasing DTCs with a scan tool does not reset the idle air trim table.
Once Keep Alive RAM has been reset, the engine must idle for 15 minutes (actual time varies between strategies) to learn new idle air trim values. Idle quality will improve as the strategy adapts. Adaptation occurs in four separate modes. The modes are shown in the following table:
IDLE AIR TRIM LEARNING MODES
Transmission Range Air Conditioning Mode
NEUTRAL A/C ON
NEUTRAL A/C OFF
DRIVE A/C ON
DRIVE A/C OFF
Fuel Trim
The fuel control system uses the fuel trim table to compensate for normal variability of the fuel system components caused by wear or aging. During closed loop vehicle operation, if the fuel system appears "biased" lean or rich, the fuel trim table will shift the fuel delivery calculations to remove the bias. The fuel system monitor has two means of adapting Short Term Fuel Trim (FT) and Long Term Fuel Trim. Short Term FT is referred to as LAMBSE and Long Term FT references the fuel trim table.
Short Term Fuel Trim (displayed as SHRTFT1 and SHRTFT2 on the NGS tool) is a parameter that indicates short-term fuel adjustments. Short Term FT is commonly referred to as LAMBSE. LAMBSE is calculated by the PCM from HO2S inputs and helps maintain a 14.7:1 air/fuel ratio during closed loop operation. This range is displayed in percentage (%). A negative percentage means that the HO2S is indicating RICH and the PCM is attempting to lean the mixture. Ideally, Short Term FT may remain near 0% but can adjust between -25% to +35%.
Long Term Fuel Trim (displayed as LONG FT1 and LONG FT2 on the NGS tool) is the other parameter that indicates long-term fuel adjustments. Long Term FT is also referred to as Fuel Trim. Long Term FT is calculated by the PCM using information from the Short Term FT to maintain a 14.7:1 air/fuel ratio during closed loop operation. The Fuel Trim strategy is expressed in percentages. The range of authority for Long Term FT is from -35% to +35%. The ideal value is near 0% but variations of +20% are acceptable. Information gathered at different speed load points are stored in fuel trim cells in the fuel trim tables, which can be used in the fuel calculation.
Short Term FT and Long Term FT work together. If the HO2S indicates the engine is running rich, the PCM will correct the rich condition by moving Short Term FT in the negative range (less fuel to correct for a rich combustion). If after a certain amount of time Short Term FT is still compensating for a rich condition, the PCM "learns" this and moves Long Term FT into the negative range to compensate and allows Short Term FT to return to a value near 0%.
As the fuel control and air metering components age and vary from nominal values, the fuel trim learns corrections while in closed loop fuel control. The corrections are stored in a table that is a function of engine speed and load. The tables reside in Keep Alive Random Access Memory and are used to correct fuel delivery during open and closed loop. As changing conditions continue the individual cells are allowed to update for that speed load point. If, during the adaptive process, both Short Term FT and Long Term FT reach their high or low limit and can no longer compensate, the MIL is illuminated and a DTC is stored.
Whenever a fuel injector or fuel pressure regulator is replaced, keep alive RAM should be cleared. This is necessary so the PCM does not use the previously learned fuel trim values.
Fail-Safe Cooling Strategy
Only vehicles that have a Cylinder Head Temperature (CHT) sensor will have the fail-safe cooling strategy. This strategy is activated by the PCM only in the event that an overheating condition has been identified. This strategy provides engine temperature control when the cylinder head temperature exceeds certain limits. The cylinder head temperature is measured by the CHT sensor.
A cooling system failure such as low coolant or coolant loss could cause an overheating condition. As a result, damage to major engine components could occur. Along with a CHT sensor, a special cooling strategy is used to prevent damage by allowing air cooling of the engine. The vehicle can be safely driven for a short time with some loss of performance.
Engine temperature is controlled by varying and alternating the number of disabled fuel injectors. This allows all cylinders to cool down. When the fuel injectors are disabled, their respective cylinders work as air pumps, and this air is used to cool down cylinders. The more fuel injectors that are disabled, the cooler the engine runs, but the engine has less power.
Before the fail-safe cooling strategy is activated, the instrument cluster engine coolant temperature gauge is within the hot zone and a temperature warning light comes on. If the overheating continues, the strategy begins to disable the fuel injectors, a DTC is stored in the PCM memory, and a Malfunction Indicator Light (MIL) (either CHECK ENGINE or SERVICE ENGINE SOON), comes on. If the overheating condition continues further and a critical temperature is reached, all of the fuel injectors are turned off and the engine is disabled.
Failure Mode Effects Management
Failure Mode Effects Management (FMEM) is an alternate system strategy in the PCM designed to maintain engine operation if one or more sensor inputs fail.
When a sensor input is perceived to be out-of-limits by the PCM, an alternative strategy is initiated. The PCM substitutes a fixed value and continues to monitor the incorrect sensor input. If the suspect sensor operates within limits, the PCM returns to the normal engine operational strategy.
All FMEM sensors display a sequence error message on the scan tool. The message may or may not be followed by Key On Engine Off or Continuous Memory DTCs when attempting Key On Engine Running Self-Test Mode.
Engine RPM/Vehicle Speed Limiter
The Powertrain Control Module (PCM) will disable some or all of the fuel injectors whenever an engine rpm or vehicle overspeed condition is detected. The purpose of the engine rpm or vehicle speed limiter is to prevent damage to the powertrain. The vehicle will exhibit a rough running engine condition, and the PCM will store a Continuous Memory DTC P1270. Once the driver reduces the excessive speed, the engine will return to the normal operating mode. No repair is required. However, the technician should clear the PCM and inform the customer of the reason for the DTC.
Excessive wheel slippage may be caused by sand, gravel, rain, mud, snow, ice, etc., or excessive and sudden increase in rpm while in NEUTRAL or while driving.
(Courtesy Alldata)
Powertrain Control Hardware
Constant Control Relay Module
The Constant Control Relay Module (CCRM) interfaces with the Electronic EC system to provide Vehicle Power (VPWR) to the Powertrain Control Module (PCM) and the Electronic EC system, and for the control of the cooling fan and A/C clutch The CCRM also contains the Fuel Pump Driver Module (FPDM) power supply relay, which supplies power to the FPDM. If any of the internal components of the CCRM fail, the entire unit must be replaced. The descriptions of the specific CCRM functions, as well as the Dual Function A/C high pressure switch are found under the individual hardware - PCM inputs and outputs.
The Fuel Pump Driver Module (FPDM) receives a duty cycle signal from the PCM and controls the fuel pump operation in relation to this duty cycle. This results in variable speed fuel pump operation. The FPDM sends diagnostic information to the PCM on the fuel pump monitor circuit.
Natural Gas (NG) Vehicle Module
The Natural Gas (NG) vehicle module provides two functions. The first function operates the fuel injectors and is referred to as the Injector Driver Module (IDM) . The second function sends a fuel level indicator signal to drive the fuel gauge and is called the Fuel Indicator Module (FIM) . IDM NG vehicle fuel indicator driver signals are based on Powertrain Control Module (PCM) fuel injector driver signals and are controlled directly by the corresponding injector drivers in the PCM. The IDM must be used to provide the NG fuel injectors with the required high current necessary for proper operation. The greater demand of NG fuel injector current warrants an increased size of the injector driver and increased heat dissipation. Given these conditions, the PCM would not be suitable for placement of these drivers. The IDM closely resembles the Electronic Engine Control IV PCM module in appearance.
The IDM injector drivers are capable of controlling the amount of current flow to each NG fuel injector. Once the fuel injector is open, the IDM NG fuel injector driver will reduce current flow sufficient to continue to hold the fuel injector open. This is done by the IDM in an effort to reduce heat. If the IDM driver does not detect the required peak current to initially open the NG fuel injector within a specified amount of time, the IDM driver will drop current to fuel injector hold open current.
The fuel indicator module is not part of the powertrain control subsystem and will not be discussed here.
The center of the Electronic EC system is a microprocessor called the powertrain control module. All applications will continue to use the standard 104-pin PCM. The PCM receives input from sensors and other electronic components (switches, relays). Based on information received and programmed into its memory, the PCM generates output signals to control various relays, solenoids and actuators.
Keep Alive Random Access Memory (RAM)
The PCM stores information in Keep Alive RAM (a memory integrated circuit chip) about vehicle operating conditions, and then uses this information to compensate for component variability. Keep Alive RAM remains powered when the ignition switch is off so that this information is not lost.
Hardware Limited Operation Strategy (HLOS)
This system of special circuitry provides minimal engine operation should the PCM [mainly the Central Processing Unit (CPU) or FEEPROM] stop functioning correctly. All modes of Self-Test are not functional at this time. Electronic hardware is in control of the system while in HLOS.
HLOS Allowable Output Functions:
Spark output controlled directly by the CKP signal.
Fixed fuel pulse width synchronized with the CKP signal.
Fuel pump relay energized.
Idle speed control output signal functional.
HLOS Disabled Outputs To Default State:
EGR solenoids
No torque converter clutch lock-up
Integrated Electronic Ignition System
The Integrated Electronic Ignition (EI) System consists of a Crankshaft Position (CKP) sensor, coil pack(s), connecting wiring, and PCM. The Coil On Plug (COP) Integrated EI System uses a separate coil for each spark plug and each coil is mounted directly onto the plug. The COP Integrated EI System eliminates the need for spark plug wires but does require input from the Camshaft Position (CMP) sensor.
Power and Ground Signals
Vehicle Power
When the ignition switch is turned to the START or RUN position, battery positive voltage (B+) is applied to the coil of the Electronic EC power relay. Since the other end of the coil is wired to ground, this energizes the coil and closes the contacts of the Electronic EC power relay. Vehicle Power (VPWR) is now sent to the PCM and the Electronic EC System as VPWR.
Vehicle Reference Voltage
The Vehicle Reference voltage (VREF) is a positive voltage (about 5.0 volts ) that is output by the PCM. This is a consistent voltage that is used by the 3-wire sensors.
Mass Air Flow Return
The Mass Air Flow Return (MAF RTN) is a dedicated analog signal return from the Mass Air Flow (MAF) sensor. It serves as a ground offset for the analog voltage differential input by the MAF sensor to the PCM.
Signal Return
The Signal Return (SIG RTN) is a dedicated ground circuit used by most Electronic EC sensors and some other inputs.
Power Ground
Power Ground (PWR GND) is an electric current path return for VPWR voltage circuit. The purpose of the PWR GND is to maintain sufficient voltage at the PCM.
Gold Plated Pins
NOTE: Damaged gold terminals should only be replaced with new gold terminals.
Some engine control hardware has gold plated pins on the connectors and mating harness connectors to improve electrical stability for low current draw circuits and to enhance corrosion resistance. The electronic EC components equipped with gold terminals will vary by vehicle application.
I had a fuel pump failure on my 1993 Mercury Sable... turned out to be the "Constant Control Relay Module"... hidden on the underside of the top of the radiator shroud. Cost $150 to replace due to a failed fuel pump relay contained therein. I wasn't enamoured of the idea.
Glacier, you're gonna hate me for saying this, but the CCRM can be repaired. Guess that'll be my next write-up.
Basically, you drill out the rivets that hold it together. The solder joint will be burned. It needs to be cleaned and re-soldered. If the relay is bad (1 in 10), you get a new one from radio shack for about 4 bucks.
Sorry... :(
I never shoot the messenger (or needlessly replace O2 sensors <g>). The thought of doing that (opening it up and seeing what was what) crossed my mind... I have no idea what was inside but the case was big enough it looked like it might have traditional relays in it...yet I surmised it might have some IC's or zeners or something, so I didn't... plus, I needed the car for my daughter coming home from college for winter break; I was busy at work, and <sigh> you know...Grrr....
I need to go see if I kept it for experimentation. I normally would have saved it up to open it up and look, but I think I was so pissed off at the entire idea I just chucked it out. If not I'll find it and we can collaborate on a nice thread that might save someone $150.
[Just looked and can't find it. I am usually such a pack rat. The first time I throw something out, the very next week I need it! So take heart fellow pack rats.]
Sparky, I'd like to hear your thoughts on Frequency and Duty Cycle. Definitions, examples. I am drawing a blank for some odd reason; but I believe duty cycle is the percentage of on time and the frequency is how many times it is on in a specific time frame. Am I correct? They are similar and Duty Cycle is similar to PWM (pulse width modulation); but I'm just trying to freshen up on a few things.
-Drew
