Ms_Lakmflx
- February 27, 2007
- Panama City Beach
- 97 Explorer XLT
Ok wifes car again, different problem.
The windows will not work by pressing the switch(es). Only way the windows will work is from the drivers master switch. This is a PITA, just think that if you have a passenger with you and he/she cannot put the window down unless you do it for them. I've checked fuses, relays and even pulled off all the door panels to check for broken or frayed wires and everything looks good. Only other thing i can think of that might cause this is the master switch itself on the drivers side but, Since i can operate all the windows from the drivers switch is there a chance its still bad? If not what other things can i check, change or buy?
