Toolbox57
- April 29, 2008
- Columbus, Ohio
- 96XLT
Original problem was engine would not start after warm up. Changed plugs and wires then went to coil pack, Mass air flow, IAC valve, fuel pump,filter,Computer from used yard, 3 times. Alternator. Code as of late P0103, we reset it three times and after the third time I reset it while at idle, It just shut off. Every time the battery would be hooked up, it would start and run, 15 volts charging. Maybe the next time we would start it, it would not start easy or if I got it running it would run real rough and smell like it was getting to much gas. I was wiggling wires while it was running and I rapped on the mass air flow sensor and was not able to get it to miss or faulter. Codes thrown in the pass was mass air flow and it was changed and would not work until the computer was changed. Then it would only last for about 100 miles or 5 minutes. I looked at the alternator voltage, and even though it is just under 15 volts, I think it was ok. I am lucky on parts because I am able to get good prices on new and used parts.
