JeffreyM
- December 16, 2019
- Florida
- 2008 Explorer Limited 4.6
We have a 2008 Explorer Limited w/ 4.6 engine. We have been having random engine shutdown over the last 6 months or so. When this happens, she pulls over, turns key off and then car restarts normally. This happens maybe once or twice a month (hasn't happened when I was in the car). I've read about the issue w/ coil breakdown on the right side of the engine, but Forscan does not show any misfire DTC. The only DTC that is recorded is P0600 - Serial Communication Link Malfunction, and P2105 - Throttle Actuator Control System - Forced Engine Shutdown. From what I have read, P2105 is more of a failsafe shutdown due to something else that is potentially dangerous.
P0600 sounds like it could be a wiring issue, but there are so many components involved in running the engine, I can't guess where to start looking. I guess maybe I should just reseat the connection to the PCM and see if that helps. I would appreciate any useful insight into what else to check.
