OKLAexplorer
- February 15, 2010
- Oklahoma
- '99 XLS
Hello all! About two months ago, my car started making this creaking sound whenever i run over a bump or i turn the wheel either way. It sounds like metal on metal or rubber on metal, like a creaky door. Whenever I push down on the front passenger end side, it makes the creaking sound. I replaced both shocks because I was told that it was most likely either shocks or ball joints. The sound still persists even after i replaced the shocks, and now i can see that the rubber exterior of front end lower ball joints is torn in the middle.
Now I have a '99 explorer xls and i'm not sure if i need to replace the entire control arms or just the lower ball joints?
Any advice would be appreciated! thank you!
