Big6ft6
- January 3, 2007
- Madison, WI
- 1997 5.0 AWD
I need to remove my driver's sidie half-shaft. I've seen two methods for getting the half-shaft out.
What is the consensus (is that a dumb questoin
: ) of everyone on here.
Unbolt upper control arm at the pivots..or undo upper ball joint?
Should I try ball joint first...then only if that is too stuck...do control arm..or is one simply a better way?
