bearskin3316
- November 30, 2004
- Cary,NC
- '00 XLT
I recently had the intake manifold gaskets replaced by the Ford dealership to correct a rough start condition in cold weather. The next week I started leaking coolant. The Ford dealership says the problem is the thermostat housing and has nothing to do with the work they did on the intake manifold gaskets. They further explained no coolant goes through intake manifolds so this is not the problem. They also said they do not touch the thermostat housing when replacing the manifold gaskets.
Need help!
Is Ford at fault? Also can someone explain why my problem is occuring and if coolant goes through the manifold gaskets. :roll:
Need help!
