Woodbutcher
- May 3, 2010
- Denver, CO
- '98 XLT
About a month ago I had my transmission fluid changed at the local Grease Monkey. I mention that because I thought this might have been due to them overfilling the coolant since they top off fluids as part of their service. A week or so later I found a little coolant under my Ex (98 XLT 5.0L AWD), passenger side, front. I found coolant dripping slowly from the passenger side edge of the radiator. No overheating, but apparently it must have leaked from the overflow tank as the fluid level was low. Over about a week I would find a little bit of coolant - maybe a few ounces at most at any one time - under the vehicle in the morning. Less in colder weather, more in warmer, but at the time it was not cold enough out to need to run the heater. Didn't appear to leak while the engine was running, just when stopped, but then it was a slow leak so it may have leaked while running as well. I checked the radiator and the level wasn't low at the time. After about a week there were no more puddles underneath, and the temp was steady normal operating temp. Stayed apparently normal for several weeks. This week I drove up to Ft. Collins, which was longer than my usual highway drive, but only about an hour. On my return trip I noticed the temp started rising to the high end of the range, so I slowed down and stopped at a gas station where I checked the radiator and it was low, so I added about half a gallon. No problem after that, and still no visible leak. The only other thing was that in the last couple of weeks my heater has been intermittently blowing cold air, then warm, then cold - fluctuating. From what I read in other threads, maybe the thermostat housing and/or the narrow hose from the overflow tank could be the culprit, but what do you think? And if that was the case, could it affect the heater that way, or am I looking at a heater core problem? Leak was at the front of the engine compartment, not back by the firewall.
