Bobmbx
- May 6, 2013
- King George, VA
- 2016 Explorer Platinum
I'm guessing that the port on the radiator that the hose fits over has some crud ridges that used to match the old hose. Now with the new hose, you've got an irregular sealing surface that isn't completely sealed.
It should seal over time, or just pull the hose off and clean the port sealing surface really well. This sounds like it was nothing more than a weep to start with, and your story suggests its getting better with time.
As for the air in the radiator, it takes a while to burp the air out of an engine after draining the system and refilling. Just keep on topping off the radiator, keeping an eye on the reservoir. Eventually everything will reach an equilibrium and you'll forget about this whole episode.
