Coolant level sensor | Ford Explorer Forums
RonParise
Ft Myers Fl
2011 Explorer limited
I poste this in stock 2011-2019 explorers but it was suggested that I add it to this area too
I now have almost 350,000 miles on my 2011 explorer. I did a preemptive water pump replacement at 200,000. so now its time to start thinking about doing it again.. I check everything regularly but I dont believe that there is anything I can do to protect against the shaft seal failing . I mean I could check the fluid level and look at the oil every morning, but if the seal fails in the afternoon Im looking at a new engine.......
So what I did was to install a water level sensor in the expansion tank. Its a little rough, but i think Im onto something
I bought a small float switch and a red light, and scrounged around my garage for the pvc pipe, wire and washers
When the float is in this position the red light is off
In this position the light is on
I suspended the switch so the float is below the cold water level mark on the tank, So if the water level drops, so does the float and the red light comes on
I attached the switch to a washer that was the exact diameter of the outside diameter of the pipe The switch hung below the washer and the washer sets on top of the pipe, The pipe unions I had were too thick walled to fit in the expansion tank so I used tape to to secure the two sections of pipe together,
And then dropped it into the expansion tank
I cut if off so the expansion tank cap would fit and wired it up. I drilled a hole near the the top of the tank for the wires, sealed it with an epoxy and then tested it by removing the hose on the bottom of the tank to drain water from the tank....the red light mounted on my dash went on... I replaced the hose, added water and the light went off....... Success
Im calling this my proof of concept, design or prototype. I intend to find a better way to suspend the switch at the right level without using tape, to hold the two pieces of pipe together or use a non contact fluid level sensor
Call it a work in progress
