wisneski7
- October 18, 2008
- Green Bay, WI
- '01 Sport
I have a '01 Sport that I picked up and has had it's share of issues. Anyhow, I left it at a friends house overnight, it got down to about 0 degrees F last night. It was only about 5 degrees this morning when I went to pick it up. It started a bit hard but once started, I left it idle outside for about 10min. before driving home. When I went out to get in, there was a puddle about 10in. by 10in. of antifreeze under the front left corner. I could visually see a couple drops come down off of the plastic from under neath while looking at it. By no means was it pooring out. I drove home the 7miles with no issues, and parked it in the garage. I just started it and let it idle for about 10min. again and there doesn't seem to be a leak anymore. Is there an overflow or pressure relief somewhere? Im guessing maybe the coolant needs changing, and it started to freeze, causing an increase pressure? Or I guess I have a leak that fixed itself somehow. Any ideas? Thanks
Aaron
Aaron
