Just replaced the one on my 1999 explorer with the 4.0 v6 OHV motor. Got the sensor out by removing the hose off of the thermostat housing which then gave me enough clearance to use an 18mm deepwell socket with a rachet and extension. This did not solve my problem however, which was that the coolant temperature gauge was not working. After researching on here, I learned that there are two sensors, the one that I replaced today was the sensor for the engine management system...the one I need to replace is located below the coil pack...guess I'll try that tomorrow.
