Cooling System Help | Ford Explorer Forums
Cooling System Help
rebscoach
Knoxville,Tn.
99sport
I recently replaced my t-stat in 99 v-6 4.0 ohv ,now I can hear thumping sounds coming from the heater core area. No other problems temp is fine and heater works great . Could this be trapped air and how can I fix this.
I don't believe explorers have bleed off screws for the cooling system, but I would try taking off the radiator cap and squeezing the lower radiator hose to see if any air comes out. How did you install the thermostat - just disconnected the hose and removed the housing? Or did you drain the system, took the radiator cap off, then the hose and the housing?
-Drew
Cooling System
Thanks Drew for responding I drained small amount out of radiator then removed T-stat housing and replaced T-stat and made sure it was positioned right then refilled radiator checked for leaks and had this problem ever since.
yeah sounds to me like it needs to burp. Heat it up, let it cool. Top it off. Repeat two more times.
Long story short. Air in the system.
