dustinjorge
- March 6, 2009
- Seattle, Washington
- '95 XLT 4x4
Could use some advice (surging/sputtering) warm start.
OK, the long and short of it is this... I've got the intermittent surging idle on warm start issue. It's random, only seems to happen this time of year and definitely only after the truck has been going for a while (Usually after a few minutes on the freeway).
Been chasing this issue for years, it seems to come and go (I haven't noticed it for quite some time, but recently it's been acting up again after my most recent tune up.) I've seen a lot of threads with similar problems, and have tried most of the solutions that just aren't solving my problem.
Symptoms:
What I've done recently (past few weeks):
Also Related:
Still on the short list:
Anybody have any ideas? Am I on the right track because I feel like I'm chasing a ghost with this problem. I'd like to get some time in under the hood this weekend, what would you suggest I start with?
Edit:: I posted in the wrong section, hope someone moves it for me
Edit2:: I started another thread for the noise problem, I don't know if the two are related or not: http://www.explorerforum.com/forums/showthread.php?t=380926
Symptoms:
- Park the car after warming up. 10-45 minutes later start the truck. RPMs up to about 1100 then down to 4-500 and and continues to 'surge' violently up and down for anywhere from 10-20 seconds then up to about 1200 for 2-3 seconds, then drops down to 700 where it smooths out.
- No Codes.
- Once in a very long while, it'll sputter/shake a bit after coming off the gas.
- Smells like it's running rich often (Cat smell)
- Idle has light bumps (I want it perfect)
- Bottom end noise, sounds like an exhaust leak/gurgling, gurgling sounds like it's coming from oil pan since I put castrol in it, could be unrelated?
- No Stalling
- Starts fine cold
- Otherwise, runs like a champ
- Cleaned IAC (1yr old motorcraft)
- Cleaned MAF (3yr old aftermarket)
- Replace Air Charge Temp Sensor (Aftermarket, NAPA)
- Clean + light oil K&N
- Oil Castrol GTX 5w30
- Motorcraft oil Filter
- New motorcraft plugs
- New motorcraft wires
- New motorcraft DPFE
- new EGR vacuum hoses (plastic ones) from pick and pull (good shape)
- Had cats checked for flow (Midas)
- Had Exhaust checked for leaks (Midas)
- Thermostat (motorcraft, prev started sticking)
- Instrument temp sender (motorcraft)
- Visually inspect vacuum lines (Prob could spend more time on this)
- FPR (Napa)
- PCV
Also Related:
- O2 sensors (3 yrs)
- Engine coolant temp sender replaced 3-4 years ago (Not sure if aftermarket, probably)IIRC I wrapped this in thread seal tape before installing, can this screw up the readings?
- Check Manifold bolt torque
- Replace ECT again (Motorcraft)
- Check for vacuum stability
- Fuel filter (Been a while)
- Fuel pressure
- Revisit MAF
