BRacing
- August 21, 2001
- Northern California
- '96 Explorer Sport
Well, when i had first bought my explorer a few weeks ago, the heater/ac controls wouldn't work. The hot/cold seletor worked, and the fan worked, but the vent controls would only allow air the be blown out the Defroster at any setting but off. Off actually worked.
For some reason, the controls now work, but the AC doesn't work. I checked the compressor to see if the clutch was kicking in, and it's not. So i'm going to check the fuse, but what else could it be if it's not the fuse?
ALSO - my power door lock doesn't lock the passanger door. The switches work, but when i press any "lock" button, the door doesn't work. The lock works with a key and manually, just not with the power. What kind of fix is this?
I keep hearing of cleaning the MAF sensor and how it can improve some bogging and hesitation. So i went to the auto parts store and purchased some throttle body cleaner that is O2 safe. But when i went to look for the MAF, i couldn't find it. Perhaps it's right in front of my face, but i don't see it. I have a '96 4.0, and have looked all around the throttle body, the black tube, and the air filter. I've seen many wires and connections, but none with torx (security star) holding them in place.
Could someone please explain in detail WHERE it is located. I've already searched the files and found info on HOW to do it, but i don't know where the MAF is! It's so frustrating. Perhaps include a pic?
I'm off to check the fuse for the AC while a await your responses...
Thanks!!!!!
Thanks!!!!!
