Paradox972
- February 18, 2016
- ohio
I have looked at tons of threads but none seem to fit my exact issue. I recently bought a 93' explorer sport 2door. I will start with the issues. 1)will not start in the morning or once the engine is cold unless I spray ether into the TB. 2) When I am driving I have slowly step on the gas pedal if i press down to much it just bogs down. now what I have done. replaced, idle air controller,plugs and wires, tried different working coils, throttle position sensor,crankshaft sensor,fuel filter, mass airflow sensor, and a brand new battery. the fuel cutoff switch is ok there are no broken vac lines and no frayed wires and all the grounds are good. I swapped relays arounds for the eec and fuel pump . I am the 3rd owner it has 141,x.. miles on it. when its in park I can rev the engine all day long but once its under load it bogs. I'm broke and can't keep throwing money at it (only paid 650$) I cannot tell if its the PCM or the fuel pump or something else entirely . I tried the paperclip key off test and the engine light never blinks it just stays solid ,even while cranking. Please and Thank you for any help. oh and it is NOT California emissions.
