mfee
- September 30, 2003
- Richmond, VA
- 1998 Mountaineer
What is this noise ? 98 M'neer with 105k miles has a creaking ( like a loose floor board under foot) noise at the front end. I can hear it as the car comes to a stop. It is definitely a rotating related noise almost like a high spot as the wheel rotates. As you pick up speed it changes to a rub type noise but then it is not noticeable at road speed - actually it may be two noises. This has been evident for the past several thousand miles - seems to be getting slightly more evident with time.
Otherwise the front end is tight and tracks very well. Shocks were just changed but did not alter the noise
Could it be CVs ?
Brake noise ?
Springs ?
Torsion bars ?
anybody have anything similar ? what did you discover ?
thanks
mfee
Could it be CVs ?
Brake noise ?
Springs ?
Torsion bars ?
thanks
mfee
