- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
We then, as well as many others here, share a similar philosophy. Keep at it!
rockstar said:So I have a working cruise now (it's been a couple of years), but I have to keep messing with it.I put in the original amplifier to test it out. It kink of works. When I press the set speed button, it accelerates 6 MPH and then cruises at the higher speed. Pretty wierd and unless you plan for this, you'd better be ready to press the brake. I guess I'll stick with my replacement amplifier.
I'm also going to try to fix the switch on the steering wheel. After disassembling the switch, there is a metal tab on the bottom of the off switch. It appears that this metal tab should be making contact until the off button is pressed which then pushes the tab downward. I'm guessing this will break the electrical contact and turn off the cruise. My tab was slightly bent. I tried to straighten it out by holding it against the switch body and putting a small screwdriver through a slot in the switch and pressing from the top of the tab. I think I have it pretty straight. Now I'll have to reinstall it to see if that fixes the switch.
This sounds suspciously similar to a problem I am having with my cruise control, except it is in the opposite direction. When I hit the SET SPEED button, my cruise coasts down about 4-5 MPH and then picks up and maintains that slower speed. From your description, I assume that putting in the replacement amplifier cures your problem?rockstar said:I put in the original amplifier to test it out. It kink of works. When I press the set speed button, it accelerates 6 MPH and then cruises at the higher speed. Pretty wierd and unless you plan for this, you'd better be ready to press the brake. I guess I'll stick with my replacement amplifier.
