Christifor
- July 29, 2014
- Pac NW
- 96 Ford Explorer 4.0 XLT
96 Ford Explorer XLT.
Recently replaced all my interior/exterior bulbs to LED (must if you haven't done so), & now my cruise control doesn't work. I had an issue with the trailer wiring initially after conversion, but then removed the converter & exterior bulbs work fine now. So far I have checked the interior fuses. Today I'll open the hood & check brake fluid level. What should I do from there? I believe the converter was shorting the lights. Now the lights also use less power, & while having the LED flasher, I hope the system doesn't read as a bulb out & has deactivated the CC.
