cv shaft help | Ford Explorer Forums
cv shaft help
mudbug0426
Allen, Tx
96 XLT V6 OHV 4x4
i have been hearing a noise the past week coming from the front end and i think ive narrowed it down to a bad cv shaft
when i go to remove the shaft, do i just take a pry bar and pry it out of the front diff, or is there a retaining clip i need to remove inside the diff before taking out the shaft?
if it makes any difference, its the shaft on the passenger side
any other tips on removal and install would be great, thanks!
No clip, just be careful not to damage the seals when you pull the shaft out.
which seals?
also, are there any kind of bearings inside the diff that the shaft sits into like it does on the oppisite end with the wheel hub?
Here's what the end of the axle tube looks like after you pull the CV out - should explain most of your questions:
attachment.php
