- March 13, 2005
- Martinsburg WV
- 84 BII "Li'l Samson"
OK, I'm new to the D44 thing. I have D44 front axle that will be under my B2. Here's the problem. I have allready cut the tube down 6" and removed some ball joints and removed the pass side axle. On that side the Ford hub is still on the brake rotor with the studs coming thru the hub. I can not get the hub off. I know on my D35 it just slids off. So I'm not to sure about really giving it a whack if there is some internal snap ring or something still in there?
Is this just a rust/corrosion thing and some heavy prying is in order?
