I have never dealt with Pioneer kits, however Trans Star Transmission Parts in Grand Prairie off Green Oaks by 360 has great kits. I have used them numerous times and had good luck. There is a fella there named Charles White (tell him you want to set a account for your dealer for cash tickets - so you walk in with cash instead of a PO#). He is pretty kewl and knowledgeable. I recommend this company because I have had good luck with them and ALL THERE PARTS ARE IN STOCK. You will definitely need to purchase a Overdrive Servo Piston, a Intermediate Servo Piston, a Overhaul Kit with Steels, and I recommend while your at it go ahead and replace the Intermediate Band, and Overdrive Band. Inspect your sun shell and sun gear thoroughly (I have seen lots of wear there in the past), also inspect the sung gear retainer in the forward clutch assembly. Other than that most other stuff is reusable. By the way get a new trans filter, be sure to totally drain the Torque Converter, and add 2 qts of fluid before reinstalling after overhaul (to the converter). Also flush out the tranny lines and cooler with brake clean and compressed air. I would recommend disassembling the valve body and working all the valves while spraying them with brake clean, be sure while removing the three torx bolts note that you should take i apart slowly so not to allow the check balls to fly out (and the two pucks and springs). I usually mark an X where every ball goes on the actual aluminum valve body with a small pick (it won't hurt it) and a O for the pucks and springs. Well that is about all the advice I have for you, I will send you some literature soon.
