Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Damarble's 01 Sport, coil sprung HP D30 SAS, SOA, 33s, 4.56s, lockers
- Thread starter damarble
- Start date
Add an avatar, upload photo attachments, and more!.
damarble
- June 20, 2008
- Washington
- 21 Bronco & 88 Bronco II
Oh and I need some ideas. My stock power steering pump is not up to the task. It was whining like mad today and must have boiled the fluid because it overflowed out the top of the reservoir. I'm assuming the OHV pumps will not bolt on. I'm not opposed to making whatever bracket is needed. In that case I should be able to go bigger, any suggestions?
damarble
- June 20, 2008
- Washington
Working on frame sliders the last two evenings. Got the main pieces cut out and ready to be welded. Probably do that tomorrow and then start on the legs.
I'm just using 1/8" wall tubing, it seems too hold up plenty well without being too heavy. The tubing under the rockers is 2x3", the outside tube is 1.9" OD Sch40 standing off 2" and curved at the ends, the legs are 2x2" (with 1x2" diagonal bracing), the plates against the frame are 3/16" 4x6". They will be welded on instead of bolts, for one I think it will be stronger, but two, and most importantly, it will be easier!
lifeguard379
- July 10, 2004
- sacremento,ca
- 93 eddie bauer 2 door
those look nice.
damarble
- June 20, 2008
- Washington
The legs to the frame are a total beotch. Got one side half way done. Apparently these frames aren't even symmetrical, so I can't copy the first side for the other side.
lifeguard379
- July 10, 2004
- sacremento,ca
whats different on the frames?
damarble
- June 20, 2008
- Washington
Sliders are fully welded and ready for install. And since there's no rest for the wicked I picked up steel for the front bumper. Scrap pile FTW, it's all 3/16 and cost less than $40.
lifeguard379
- July 10, 2004
- sacremento,ca
that sucks. where the ball joints old or new?
damarble
- June 20, 2008
- Washington
They were the old ones. The guy that setup my gears said they were OK so I didn't bother replacing them.
It probably still won't be too soon that I get the D44. Not really in the budget now. Yesterday cost me $250, dolly rental, new ball joints all around and new axle shafts.
iammattchew
- October 3, 2003
- Belleville Michigan
- 2001 Sport
hehe nice carnage dude! My 01 is getting this treatment soon.
Birfield joints?
Birfield joints?
damarble
- June 20, 2008
- Washington
Birfield joints?
Eh the u-joints are fine, just need to upgrade to the 297X joints instead of the little 260Xs, which I did today.
Oops! What year XJ is that axle out of?
91 or so, not sure exactly I didn't get to pull it.
damarble
- June 20, 2008
- Washington
you could just upgrade it to a super 30.. then you wouldnt need a d44
But oh so tempting to get a D44. Theres a 79 Bronco at the JY right now... $90... I really should just go get it...
I did get gas tank and transfer case skids, second set of shafts for the 8.8 and D30, power steering pump from a F150, auto trans cooler from an Ex for a power steering cooler, and some misc stuff.
Also grabbed a set of 8.8 disc brake assemblies, they are very rare and are grabbed up quickly. A 96 had just come in this morning. I'll save them for my next axle upgrade so I can sell my current 8.8 hub to hub to the Jeep guys for big $$$. How does full width D44 and 8.8 sound?
