Explorerdude
- July 12, 1999
I have a 94 Explorer XLT that has 92,000 miles on it. I am a 2nd owner of the truck. I bought the truck with 35,000 miles on it. I had my transmission fluid changed at 85,000 miles because I noticed a very noticable discoloration in fluids. It was a little bit darker than motor oil. I had my mechanic change the fluid and filter then. When I had the fluid changed I drove the truck often but put only probably around 150-200 miles on it per week. I also didn't do any wheeling with it at all then.
Today I just changed my trans fluid because it appeared to be getting that dark color to it again. When I drained my pan I noticed a change in color from a slight brownish tint to a darker brownish tint. When it was in my drain pan it looked like used motor oil. I didn't notice any metal shavings in the pan at all. The pan had a film that almost had heat markings on it. It looked like the fluid may have been reaching high temperatures and discoloring the pan more than normal. In the duration of that fluids "life cycle" I drove the truck daily at speeds of 70+MPH and did a good bit of stop and go driving, with some mild wheeling here and there.(All of this was done pre-lift and tires) I have 3.73 rear gears and a transmission cooler on the truck.
I am going to purchase a transmission fluid temperature gauge for it to see if I my cooler isn't working properly.
What do you guys think the problem may be??
Has anyone else experienced the same problem??
What could I do to resolve this??
I haven't gotten bigger gears yet, is there anything I can do to keep from frying my transmission or from changing the fluid so frequently?? I probably won't be able to get gears until early next fall.
Any help would be greatly appreaciated.
Thank you!
Happy Wheelin,
Joe Dead Link Removed
94 Explorer XLT
4" Superlift Suspension
Superlift Steering Stabilizer
33X10.50 BFG AT KO's
Blazer Fog Lights
Warn Manual Hubs
Highlift Jack
Thank you!
Happy Wheelin,
94 Explorer XLT
Blazer Fog Lights
Warn Manual Hubs
Highlift Jack
