Darn horn dont work! | Ford Explorer Forums
EliteRaven
Ravena NY
92 2dr Explorer XL
Hi all,
I am confused as heck about my stupid horn in my 92 EX
It worked at first but right now it doesnt work at all. inspection time is a comin and I really need to get it fixed. I checked the fuse its fine. I figured maybe the horn itself went south but I hot wired it and all is good. ok maybe the switch so I pulled the steering wheel cover and checked if it was stuck nope all good then I figured I would take off the wires to the switch and connect them hot wire the horn no toot toot grrrrrrrr. I went to the local parts store to pick up a relay for the horn but I do not have a clue where it goes and my darn haynes manual is in storage doh. any help or info would be greatly appreciated what else could it be.
Len
Roll your window down stick your head out and go
HONK !!!!! :)
Your horn relay should be in the fuse box under the hood. Which one I am not sure though , but there likely is a diagram on the fuse cover.
Mines doing that right now too, if I pull the connections off the horn and wiggle them back on it works for a while. Maybe corrosion ,I dont know need a closer look but its in a hell of a spot.
I checked the fuse block under the hood but there are no relays located there Im ata loss :-(
Len
