Daystar Coil Spacer question. | Ford Explorer Forums
Bracken53
Worcester, Massachusetts
91 Explorer Sport
Allright so here's my story.
I got a set of what I'm pretty sure are Daystar coil spring spacers to lift the front of my truck to make a little bit more room for my 31's. However, when I go to put them on they don't really seem to fit very well. The top of the spacer that I believe is suppose to sit inside the spring doesn't really fit into the spring. The other probelm is that the hole in the bottom of the spacer is so big that the spacer almost doesn't sit on the pad that original held the spring at all, I get the impression that if i actually installed them they would just collapse because so little of the spacer was sitting on anything.
Now is it just me or does it sound like I got the wrong parts?
Any thoughts or comments are appreciated, I just hope what I just said actually makes sense to someone.
Thanks for the sanity check, I certainly didn't think they were the right ones. Now I just need to convince them to send me the right ones.
