PaulBinCT
- February 3, 2013
- New Haven, CT
- 2002 Explorer
Hey folks... What a great forum! Awfully glad I found it!
So, I have what seems like the common Explorer heater dilemma. Of course, now that we have a cold snap, my heat stopped working (2002 Explorer). My problem is 2 fold. First, in a desperate move to get heat while away from home, I followed a YouTube tutorial and reached around behind the glove box and tried to get fiddle with what I misunderstood to be the blend door, in the course of which I knocked off the linkage, not to the blend door of course but, I believe, from the solenoid that controls where the airflow goes. When I move the control from off to the various positions, I can feel the linkage move but the "far" end has come off. So, my first question of course is... how screwed am I? I intend to tackle this again in the morning and the first order of business will be figuring out how to reattach this. I'm praying I don't have to remove the entire dash
The "bigger" issue is trying to figure out what the heat problem itself is... I've read a few threads here and I can't figure out if the issue is the door, the actuator or something else. The symptom is cold air only of course but when I turn the temp control back and forth, there is a change in the sound of the air flow so I assume the actuator is moving the blend door... or is that not a safe assumption? I'm assuming that if the actuator was shot, changing the temp control would have no effect, but maybe I'm wrong?
What I'm trying to avoid, aside from wasting money, is tearing it all apart, and finding out I don't have what's needed for the repair which would mean reassembling everything to where it's drivable to get the correct parts... and repeat.
Anyway, thanks in advance for any advice and for a great source of info!
Paul
Paul
