Did I get hosed? | Ford Explorer Forums
Did I get hosed?
Fays
Ithaca, NY
1999 Ford Explorer
I recently had some repairs done on my 99 Explorer. At first, I was just getting the catalytic converter replaced, and I paid fro it up front. Once I went to pick it up, I was told by my mechanic that some additional repairs were needed, so they went ahead and did them (and of course added it to my bill). Here is my question:
The shop replaced the upper and lower ball joints, and also the outer tie rod end. When I picked up the truck, my mechanic warned me that it would probably squeak for a while, but then it should stop. Here I am, about 600 miles later, and not only has it not stopped, but the wheel shakes and I hear a rubbng sound when I turn the wheel hard. Also, there is a continuous, rythmic squeaking coming from the passenger side (not sure if from the front or rear- but I think its the rear). I was told by the shop that it is because I need my brakes replaced. What the hex?
1st:
I would have said "Thank you for fixing it, but I didnt authorize that work, I'm not paying for it."
2nd:
Find a new mechanic. New parts should never make noise (unless its part of the stereo system).
Ahaha, or if it's a new muffler. ;)
But, it sounds like they did a bad job. Go back to the shop, tell them to fix the problem or you'll take legal actions. Usually that gets them worried cause they know they screwed you over.
A muffler is supposed to suppress noise, not make it. :D
