- January 3, 2003
- outside shovelling snow
- ................ 96 XLT ™
@Tony407, for the signal to the LC2i, did you tap into the sub output, or a full-range output?
I have an LC2i in my Budget Bass setup. OEM head unit, OEM speakers, aftermarket sub and aftermarket amp to power it. I tapped right after the OEM door speaker amp for signal. There was not enough signal before the OEM amp for a past PAC high-low converters I used in the past. It's good on some music, and bad on other. I have no idea if the LC2i is set up as best as it could be. I definitely am not going to win any audio competitions for sure. I do like how it compensates for the bass cutoffs at higher volumes.
My Paseo with aftermarket stereo everything is a way better setup. I have no plans to upgrade the OEM stuff in my Explorer unless needed.
