- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
now back to drums vs discs................... elevators and escalators still use a drum style brake with huge shoes just FYI more people travel in elevators and escalators every day then your trucks could ever imagineokay okay not a fair comparison, but disc brakes have not made their way into vertical transportation YET
One of the big pluses for disc over drum in automotive applications is the ability of discs to work well in all weather conditions. It was not at all uncommon for drum brake cars to lose all braking power after driving through deep puddles. Back in Illinois in drivers ed class they used to teach you to drag the brakes when driving through deep puddles to help displace the water. I don't think that the brakes of an elevator or escalator would ever be subject to such conditions.
I had a '70 LeMans which lost it's brakes when they got wet.... Anecdotal info
And on to the cut and paste...
Can Brakes Get Wet | Brake Experts
Drum brakes were commonly used in the front and back of older vehicles. They can still be found in less expensive modern vehicles, but typically only for the back wheels, while disc brakes will be used in the front.
Disc brakes have a rotor (or disc) that rotates with your wheel, and is stopped by two brake pads that squeeze the disc to slow down your car. These are the most common brakes, which you can see on the majority of modern cars – especially in the front.
These two types of brakes, unfortunately, respond differently to wet environments. When drum brakes get wet, water can sometimes get trapped on the inside of the drum. While the drum is spinning, the water will spin on the inside and work its way between the brake pads.
This will decrease the car’s braking ability for a few seconds, until the water is released. This is why anyone who had spent more of their time driving older cars may advise you to use your brakes for a few seconds after driving through a puddle.
When disc brakes get wet, the water isn’t trapped inside of a rotating container, and can easily fall away from the brakes. This is why braking for a few seconds after driving through a sizable puddle is less necessary with newer cars.
